Metabo 9" angle grinder
Old 01-12-16, 08:17 PM
I purchased a used metabo 9" 18 amp angle grinder model# W26 230.The problem I am having is immediately when trigger is engaged it trips breaker.Disc turns freely when turning with hand.I tried to pull model up and can find this model but not in the 18 amp.The 18 amp has been discontinued for what ever reason and 15 amp is highest you can purchase now.Any help would be appreciated.
Old 01-12-16, 08:34 PM
Received 1 Vote on 1 Post
Man, what a beast. Does it spin the disk at all when you trigger it? Or just pop the breaker?
I assume you at least have this on a 20 amp circuit?
Old 01-12-16, 08:36 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The start load could be more than 50 amps. While that is only momentary you would probably need at least a 20 amp circuit with no other loads to use it. Is the plug a NEMA 5-20? What amp circuit are you trying to use it on?
Old 01-12-16, 09:03 PM
Disc does spin but trips breaker it is on 20 amp breaker with other items on same breaker.
Old 01-12-16, 10:15 PM
ray2047's Avatar
That is your first problem. If it truly draws 18 amps it at least needs a dedicated 20 amp circuit but really it probably needs a 25 amp circuit but that would require a NEMA 5-30 plug and receptacle. Try it as the only load on a 20 amp circuit.
Old 01-12-16, 10:26 PM
ray2047's Avatar
Moving to electrical because this may be more of an electrical problem.
Old 01-13-16, 07:55 AM
Received 42 Votes on 40 Posts
Could you still return it? If it won't start alone on a 20A circuit, I would say it's either a faulty unit or a faulty design.
Old 01-15-16, 02:32 AM
I have a 6500 watt generator so I decided to see if grinder would run plugged to it.Cranked generator plugged grinder in and it runs fine.Did some cutting and grinding wth no problem. Thanks for all the help.
Old 01-17-16, 04:54 AM
It has higher starting amps, and needs both a higher breaker switch at the panel and a higher rated plug receptacle as these have breakers built in them. Fortunately, most tools are garbage advertising their actual power, so if it fits in a standard outlet, its 15 amps only and the load is just from the rest of the items on the circuit somewhere else down the line. Say you do upgrade the breakers, remember the wire to and from the locations should be able to handle the new rated load or they will catch fire or if your luckly just trip the breaker if you have that type of breaker protection. Since your just bumping up 5-10 amps and the duration is short I wouldnt worry about that.
