Question about wiring a breaker box
Old 01-13-16, 05:47 PM
I have an Square D electrical box that I am wiring up in a cargo trailer. I believe this box is considered a sub panel. It's a 70AMP box. I am installing a 30AMP RV hookup plug on the outside of the trailer to be able to receive power. I am confused on wiring the feed into the box from the 30AMP plug. The plug is a 3 wire plug. I am only setting this up for 120V. I found a picture of someone elses online that is using a box like mine but it is being feed by a 3 wire (3 wires and bare ground) but my setup will be just 2 wires. I just don't know how to get power to both breakers without jumping the black wire from one breaker to the other since I have 4 possible wiring points in the panel.
Here is the pic of the one I found. The orange wire is the feed wire.http://i235.photobucket.com/albums/e...psad0nimp8.png
Old 01-13-16, 06:04 PM
Received 410 Votes on 385 Posts
Welcome to the forums.
I couldn't find a picture of a blank subpanel so I hijacked this one. You'll be using black instead of red but and you will need to jump across the two feed lugs.
The white wire will go to an insulated neutral bar.
The green wires goes to a separate ground bar..... as shown by the blue arrow. The panels don't come with a separate ground bar. You can pick one up where you purchase the panel.
Old 01-13-16, 06:32 PM
Ok...thanks. So I can jumper the breakers.
Here is my blank box with an updated wiring scheme. Is this correct?
Old 01-13-16, 06:48 PM
pcboss's Avatar
Received 33 Votes on 28 Posts
That configuration can overload the neutral. You are creating an improperly wired MWBC.
Old 01-13-16, 06:49 PM
pcboss's Avatar
Also you can only have one wire in the lug.
Old 01-13-16, 07:14 PM
Ok...then how do I need to wire up this box?
Old 01-13-16, 07:33 PM
Boss.... he is running that sub panel on 120vac. There is no mwbc.
He's basically wiring that box like you'd find in a motorhome.
You can connect two tails to your black supply wire so that there is only one wire in each lug.
