Switch Stopped Working
Old 01-14-16, 08:51 AM
My garage light switch stopped working. ALL REMAINING circuits/lights, etc in my entire house work fine.
WHen I put the tester to the bare wires (both black ??) it flickers. Help
Old 01-14-16, 09:25 AM
ray2047's Avatar
When I put the tester to the bare wires (both black ??) it flickers.
If it is a non contact tester it means nothing. They can't be used for real testing. If it is a multimeter the switch isn't where you test. How can the wires be bare if they are black? Do you mean the wires connected to the switch?
Please explain what you mean by:
Does the light stay on all the time or do you mean the light doesn't come on? How many total wires in the switch box and how are they connected.
Old 01-14-16, 09:58 AM
O K THis is the switch to my garage over head lights. It's worked for 12 years
and has stopped. When I pulled off the cover and pulled the switch out,
there were two BLACK wires attached. Not what I expected to see.
I unscrewed the wires and put my tester to them and got nothing.
I checked the tester all over the house and it works fine. It's just a cheap one.
I had disconnected the smoke alarm in the living room. I reconnected it
went to garage and put tester on wires and it FLICKERED this time
in the 110 window.
Old 01-14-16, 10:43 AM
Handyone's Avatar
If you disconnected the alarm from the house wiring, you might have made a mistake in that box.
Was the alarm hard wired?
Old 01-14-16, 10:56 AM
pcboss's Avatar
Often time the circuit will feed to other parts of the house. If you disconnect a hot in the smoke alarm you may have killed the outgoing power to the garage.
You need to test from hot to ground or hot to neutral.
Old 01-14-16, 11:07 AM
ray2047's Avatar
If it is a non contact tester that proves nothing. Their primary problem is false positives. Actually even with a multimeter testing across the switch accomplishes little in the way of identifying the problem.
Using a multimeter, preferably analog, (or a neon light tester, or a solenoid tester) measure from ground to each black wire. If there is no ground there should be two white wires connected together. Measure to those. Best to disconnect the two black wires when testing.
