Doorbell
Doorbell
I just purchased a home and the old doorbell chime on the wall is not working correctly when the outside switch is pressed. Can this simply be changed out with a new wall chime unit or is there more involved that a simple changeout?
Temporarily Suspended
There are 3 things that make a bell work, the outside button, transformer & the chime. Use lighter fluid to lubricate the chime not oil. To answer your question, it can be replaced but test the other things first.
