Chewed up oven power cord: DIY or professional
Old 01-17-16, 10:50 AM
So this week I came to the unfortunate realization that we have a small mouse problem in my house. Taking care of the pest prevention steps, but last night I found that they had partially chewed through the power cord of my gas oven* (luckily I can at least start the range with a lighter, but until I know the cord is fixed the power is completely unplugged so I don't burn my house down).
My question is: Should I have a professional check out and fix the chewed cord, or could I (as a bit of a novice) repair the cord with a bit of electric tape? Only the outer covering of the cord seems chewed, the wires inside seem to be undamaged.
And if it is a job for a professional, should I call an electrician or a large appliance repair shop? Or would both work just as well?
Thanks!
*By "found out" I mean that I was trying to blindly stuff some steel wool into the entry hole and was thrown back a few inches when it made contact with the damaged piece of the cord. Ouch.Name:  IMG_20160116_193252171.jpg
Old 01-17-16, 10:55 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Moved to electrical.
Is this a cord that plugs in? Can you give us a close up picture of the damage.
Old 01-17-16, 10:57 AM
Received 1 Vote on 1 Post
And what's the make and model of the oven? May be easy to replace.
Old 01-17-16, 01:34 PM
Received 380 Votes on 357 Posts
That looks like a standard appliance power cord that would just have a standard right angle plug on it and would plug directly into a receptacle behind the range which I see you are missing.
Usually the back cover of the appliance needs to be removed to replace that power cord. An electrician, an appliance tech or even a handyman could replace it.
