electrical project
Old 04-10-01, 10:45 PM
I'm planning on diy'er another circuit in the garage with a receptacle and a switch controlling two outdoor receptacles. Inside the garage will be a receptacle for general purpose use (lighting, electrical weedeater or air blower for occasional yard work) and the switch. This switch turns on/off the outside plugs. The other two receptacles will be located outdoor underneath the eaves (for two motion detection sensors or holiday lights). My questions: a) How much of a circuit breaker(10/15/20A)? b) Since the wires will be underneath the eaves, what type(bx cable,conduit,insulated indoor wire) and gauge? c) Does it need to be gfci'd? What is acceptable? Your advice will be appreciated.
Old 04-11-01, 03:57 AM
Guest
15A for 14-2, 20A for 12-2, outside receptacles on a GFI, no exposed RX on eaves ( exposed to the elements) unless you use UF wire, and/or conduit
Old 04-12-01, 07:23 PM
Question gfci wiring
Thanks wirenut! Since gfci is not grounded, so the ground wire coming from the breaker is connected to the switch and receptacles?
Old 04-13-01, 04:26 AM
Guest
ground everything you can, if no "bare" conductor, introduce one from your panel.
Old 04-13-01, 07:34 AM
Jun54e,
What do you mean by, "Since gfci is not grounded." If you have a ground wire, why wouldn't the GFCI be grounded? Do you have some confusion about GFCI?
