Relocating oven in remodel question
Hello, I'm relocating my oven in a kitchen remodel. The service from the panel is old 3 wire and I understand this should be changed to 4 wire per code. The oven is being moved about 6ft.
Should I attempt to do this myself?
Check with the inspector,if that is considered an existing situation you may get away with splicing in an appropriate sized "J"box, not the best solution.
Please define Oven.
An oven is in a cabinet, such as a double wall oven.
A Free Standing Range stands on the floor in a 30" wide opening. I ask because there are sometimes differences in wiring.
Either way, can you move this cable without any junction boxes? It might be grandfathered.
That said, it's always best to install new cable.
to be honest, confidence is high but skill comes basic diy wiring around house.
You will need 6-3 NM-b cable.
I have got to ask why you called a stove (range) an oven. Isn't the first time I have seen a member confuse them. I'm wondering if it is a regional thing. Do other call stoves ovens in your area?
It's a free standing and I would like to bring it up to a 4 wire with a 50 amp breaker. Currently a 40 amp breaker
