Understanding electrical switch ratings
Old 01-27-16, 01:33 AM
CircuitBreaker's Avatar
Received 1 Vote on 1 Post
The fan I found also needs a new speed control switch (The plastic shaft broke)
The motor draws 4.1 Amps on high
the switch I found is rated 13 Amps at 120Volts or 10 (3) AMPS at 250Volts. I get the 120 Volts portion (Which is the voltage I would be using the switch at anyway but I am curious as this is not the first time I have seen this used in switch ratings) but what is the 3 in parenthesis for?
Thanks
Old 01-27-16, 05:57 AM
Received 33 Votes on 28 Posts
The number in parenthesis is the maximum electric motor horsepower the switch can interrupt at the stated voltage, 240 VAC in your example.
Old 01-27-16, 05:59 AM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
What is the model# of the switch?
Old 01-27-16, 06:35 AM
Received 21 Votes on 21 Posts
One horsepower in electrical terms is approximately 750 watts, or slightly over 3 amps at 240 volts.
