THHN wire under baseboard heater?
Old 01-27-16, 08:08 PM
L
Received 92 Votes on 80 Posts
I'm planning on installing 2 space heaters against cinder block wall. Load center is on the same wall.
I am going to install 1/2" PVC conduit from the load center to 1st baseboard heater, then from 1st baseboard heater to 2nd baseboard heater.
Baseboard heater has a knockout at the bottom, but there is no bottom or back at that area.
No back or bottom.
The question is, is it ok to run THHN wire in this location without conduit?
My guess is no, but just had to ask.
I could just run 10-2 NM wire, but its just that THHN stranded wire and a little cheaper and easier to work with.
Old 01-27-16, 08:26 PM
Received 1,335 Votes on 1,234 Posts
Any idea what that knockout is for ?
The single conductor wire must be in an approved raceway ... conduit or equivalent.
Old 01-27-16, 08:30 PM
L
There wasn't any instruction that I can find saying what that knock out is for. But I have used it to feed 12-2 NM from right side (because that is side where wire coming from) then pulled to left side, where I installed thermostat in past.
Just had 12-2 NM seating under baseboard heater.
