Wiring Issue
Old 01-30-16, 11:42 AM
Wiring Issue
I have a 12v Temperature Controlled Switch. When it's hot the switch is on, when it's cold the switch is off. When the switch is on it turns on a solenoid. When the switch is off the solenoid is off. I want to be able to be able to turn the entire system on/off. Also, if the Temperature Controlled Switch fails, I want to be able to turn off the Temperature Controlled Switch and keep the Solenoid on. If possible, I want to do both things with one switch.
Old 01-30-16, 12:07 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
With out knowing what this controls your question can't be accurately answered.
Old 01-30-16, 02:30 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Just put a single pole, double throw (SPDT) switch with a middle off position in parallel with your temperature switch.
Old 02-01-16, 08:00 AM
Thanks Tolyn. That should work
