Using 3-wire to Add an Additional Light?
There is a ceiling fan on my back porch. It was wired using 3-wire cable to 2 switches inside the house (one for the fan, one for the fan light).
The builder did not put in a light kit for this fan, thus one of the switches is unused. I don't need a light kit anyway, so here's what I'm thinking...can I tap into the unused wire inside the fan box and continue the run of this cable to a new j-box? My backyard could use a flood light and this would be an easy way to add one with a dedicated switch.
Would this be considered an "acceptable practice" for using an otherwise unused switch?
Yes it sounds like this is OK. If you only want just a light in the new location, you only need 12-2 or 14-2 cable from the existing fan box to the new location; however XX-3 cable is not wrong, just overkill. Match the gauge of the existing cable #14 or #12.
Thanks. Yes the plan was to match up the existing 12-gauge cable and continue the run to the new box with 2-wire.
Wanted to run the idea by the group just to make sure that practice didn't throw up any red flags.
