Charging AGM Batteries
I just bought a Noco Genuis G1100 battery charger/maintainer and it has a setting for "normal" charging and "cold/AGM" charging. I am currently using it to charge my dirt bike battery, which is an AGM battery, so I will of course be using the cold/AGM setting. My question is what does the charger do differently for an AGM battery? And does "cold" refer to charging a physically cold battery (sub-freezing)? Do AGM batteries need to be charged more gradually or more rapidly? Perhaps it's the floating voltage applied after charging. I read that AGM batteries are more sensitive to over-charging.
AGM and and regular wet cells charge similar with a slight voltage difference.
Typical chargers will not charge a low S.O.C agm batts below like 10 v... They will kick off and not chargel. And many times you have to trick the charger by hooking another semi charged battery in parallel to start the charging process..
[ATTACH=CONFIG]62502[/ATTACH]
AGM batteries ARE more sensitive to overcharging so an AGM charger has a lower terminal (ending) voltage than will a standard (wet) lead-acid battery
From my knowledge anyway...
Its only a 1.1 amp maintainer charger so ignore my graph I posted...
Sorry I did not look up actual specs.....
NOCO Genius® G1100 - Wicked Smart™ Battery Charger (1100mA, 6V/12V)
I'm measuring the battery in situ with my digital multimeter. Based on what I've read, an AGM battery should be floated between 2.2V and 2.3V per cell. My battery is 12V, so that's 13.2V to 13.8V.
I just monitored the voltage while it went through a cycle and it fluctuates between 13.5V up to 15.2V, back down to 13.5V, up to 15.2V again then settles to 13V at 100% charge, then gradually drops to 12.8V. Weird.
That charger you're using uses pulse technology for charging and it may also introduce AC pulses for desulfating batteries.
I'm beginning to think that maybe I have a bad battery. It's been connected to the charger overnight and it's sitting at 12.8V. That's only 2.13V per cell. Based on what I've read, the lowest recommended float voltage is 2.2V. The battery is only a year old, but I don't ride my dirt bike for extended periods so the battery probably doesn't have a chance to charge fully everytime I ride. I suppose I should be connecting the charger when I get home from riding and leaving it connected until next time I ride? By the way, the battery is a Yuasa YTZ7S, and it wasn't cheap.
A fully charged battery is 12.7 volts.. If its fully charged then your charger may be in standby..
Drain the battery some and put it back on the charger..
You did say this so I see nothing wrong ...
It states its a 7 stage charger in the docs...
It's only in standby when you first plug the AC cord in. After it charges the battery, the 100% LED remains lit and the mode LED remains lit. I'm wondering why the charger is not floating the battery at 2.2V to 2.3V per cell as stated in everything I've been reading about charging and maintaining AGM batteries.
