4-way illuminated toggle?
I apologize if this shows up twice. I posted it before, but now I can't find it so maybe it never went through.
I have a light switch that is controlled from three locations. One of the switches is a four-way switch, and two of the switches are three way switches. I'm trying to replace the four way light switch with an illuminated four way light switch, that is toggle style, and not a decora.
I can't find it anywhere! Does this not exist?
Thanks!
Thanks!
I checked..... this is your only thread posted on this subject.
I had never seen an illuminated four way switch before so I checked and didn't find any toggles either.
I did some checking as well with the same result. Looks like you are SOL as far as a standard toggle with a lighted handle. Bummer.
Now you MIGHT be able to find a wall plate that has LED edge lighting that will work in your situation. I know they make the plates but I don't know if they will work with a four-way switch.
