Mounting electrical boxes to concrete
Old 02-09-16, 06:21 PM
Are the basic masonary (blue) screws with the PLASTIC ANCHOR you hammer in acceptable to mount a box to concrete?
as opposed to the tapcons or metal anchors I bet most guys prefer.
Old 02-09-16, 06:26 PM
Received 3,422 Upvotes on 3,068 Posts
I prefer Tapcons but they don't allow any wiggle room if the drilled hole is a little off so the plastic anchors are perfectly acceptable. Recommendation..... use three.
Old 02-09-16, 06:40 PM
A
Received 83 Upvotes on 75 Posts
Masonry (blue) screws are synonymous with the brand name Tapcon. If you use a plastic anchor you don't use a masonry screw - you use the screw that came with the kit (usually a standard machine screw).
Old 02-09-16, 07:49 PM
the one I am refering to are phillips blue coated screws that use a green plastic plug....
Old 02-09-16, 07:59 PM
Usually when you use the plastic anchors.... they come with their own screws that are just steel with no coloring.
The screw below is a tapcon and goes directly into masonry with no anchor.
Old 02-10-16, 04:52 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Plastic anchors and machine screws should be fine for most usages.
Old 02-10-16, 05:44 AM
Are you generally using the name brand "tapcon" to describe all masonry screws?
What I used were 3/16 x 1-1/4 phillips blue coated masonry screws (not tapcons). I assumed they were not self tapping like the tapcons. So I used the green plastic plugs labelled for that size of screw and I used the right bit to drill for the plugs. The plugs were more cylinder like not like the ones pictured below that you see in the kits
I used them on 4 boxes and a few straps in my basement. Should I be concerned that I didn't use the right material?
Old 02-10-16, 07:12 AM
I
Received 45 Upvotes on 43 Posts
No concern, those expanding anchors are just fine for normal mounting of boxes and conduits on masonry. For a panel, I'd use something more substantial like Tapcon (or equivalent) or stainless steel lags w/ lead anchors. Even still that's probably more than is really necessary.
Old 02-11-16, 11:07 AM
E
Received 3 Upvotes on 3 Posts
a 10mm plastic expanding anchor has a pull out strength of over 1 ton.
Old 02-11-16, 02:42 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Many many years ago I used to buy 1/4" plastic anchors in boxes off 100 and #10 X 1" panhead sheet metal screws also in boxes of 100.
