Adding a 50 amp circuit for a welder
Old 02-14-16, 11:11 AM
I looked at my main service panel and it only has 4 breaker knockouts.
2 are for the main 100 amp disconnect and 1 has a 20 amp circuit to the garage,which leaves 1 breaker i can add.
my sub panel in the garage is full.
my questions are,why is there only 4 knockouts in the main panel and how would i add a 50 amp circuit to my garage for a welder?
thanks for any help on this!
Old 02-14-16, 11:23 AM
Tolyn Ironhand's Avatar
Received 329 Votes on 283 Posts
Because that was how it was made and that is what was installed.
Add another sub panel in the garage. The panel in the garage is where most of the branch circuits come from, I suspect it will be fed with at least a 100 amp feed. You can move some smaller circuits from the full panel to the new sub panel and then install the welder in the full panel, or feed the new sub panel with a 100 amp feed and install the welder circuit there.
Old 02-14-16, 03:26 PM
CasualJoe's Avatar
Received 105 Votes on 93 Posts
It might be easier to just replace the existing garage subpanel with a larger panel. How many amps is the garage subpanel fed with?
Old 02-15-16, 06:05 AM
i'm not sure how to tell but the main panel has a 100 amp breaker so does that mean it would handle 100 amps as well?
Old 02-15-16, 06:51 AM
I
Received 44 Votes on 42 Posts
Not necessarily. Pictures of all the panels with the covers off would be very helpful.
Old 02-15-16, 08:58 AM
CasualJoe's Avatar
In post #1 you mentioned a 100 amp main breaker. Is this the 100 amp breaker you are referring to or is there a second 100 amp breaker? Yes, pictures would be helpful.
