What should I do with this wire?
Old 02-18-16, 12:56 PM
The previous owner had wired the microwave to a kitchen light circuit in the ceiling. I relocated the mico and need advise on what to do with these live wires, ceiling access will be difficult. I'm sure you cant just shove them into the wall.
PatrickName:  GetAttachment.jpg
Old 02-18-16, 01:11 PM
Received 53 Votes on 50 Posts
Sorry, what is it we're looking at in the picture - wires just protruding from a wall/ceiling without a junction box?
Old 02-18-16, 01:12 PM
Received 380 Votes on 357 Posts
No.... you can't just stuff live wires in the wall. What are your intentions for the wall finish ?
Old 02-18-16, 01:20 PM
The wires originally terminated at a receptacle located in a cabinet for a microwave below. I have relocated the microwave and no longer need this and there will be a cabinet at this location
Old 02-18-16, 01:36 PM
Can you disconnect them from the circuit at the other end so they are no longer live?
Old 02-18-16, 01:46 PM
That would be the best solution but access to above the ceiling would be difficult do to my size. I'm looking for alternative ideas.
Old 02-18-16, 02:09 PM
The only other option I can see, then, would be to install a junction box and put a blank plate on it for these wires to reside inside.
Old 02-18-16, 02:10 PM
Received 42 Votes on 40 Posts
What's on the other side of the wall? You could cut a j-box through to that side and put a blank cover on it.
Old 02-18-16, 06:45 PM
pcboss's Avatar
Received 32 Votes on 27 Posts
The other end of the wires should be in an existing fixture box. It may not take much to disconnect them.
Old 02-19-16, 06:42 AM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
Can you tell what is on that circuit?often times in older homes that may have been a feed to the exhaust hood over the stove and someone converted it to a micro feed,I would bet it is fed from a ceiling fixture near the hood, in which case shut the circuit breakers off until you turn the ceiling fixture off and I bet the wire will be dead,try that and report back.
Old 02-19-16, 01:35 PM
Handyone's Avatar
I think Geo is right because I deal with this all the time during kitchen remodels.
It was OK to power a vent hood from the lighting circuit. Someone later changed the vent hood to a Microwave Hood Combo and didn't bother to install a new circuit.
You can just shove them in the wall... But only after finding the other end and properly cutting the wires to abandon them in the wiring box.
