Grounded, single receptacle
I am installing a single grounded receptacle with existing wiring that was connected to a range hood. The receptacle says to connect black wires to each screw except the green one where the ground wire goes. What I want to know is where does the White wire go to? There are only brass colored screws on this receptacle, no silver ones.
I also would like to know if I need to use a jumper on the ground wire to connect the ground to the wall box as well as the receptacle.
Thanks,
Garth
Thanks,
Garth
