20 amp breaker not resetting.
Old 03-02-16, 04:28 PM
Roeboat109's Avatar
My electrical panel and system are square d.An electrician found the one 20 amp breaker that would not make good contact with bar where it plugs in.The electrician took out the breaker that would not reset and added it to another 20 amp breaker just below it
It now seems fine.My lights are no longer blinking and it seems ok.Its square d.From what i understand square d can be double tapped like this.I read its the only one that accept double taps.
Old 03-02-16, 04:40 PM
F
I detest that term, "double tapped" and prefer it stated as two wires to the same circuit breaker.
No, Square D is not the "only" brand that allows two wires although I don't off hand remember the others. The easy way to tell is if the connection is via a large-headed screw against a pressure plate with a wire groove on either side of the screw shank. You always need to be certain that both wires are the same gauge.
If the connection is via a headless screw in a "cage" that presses the wire into a vee (or a flat in larger sizes) then only one wire can be used.
Old 03-02-16, 05:07 PM
Received 3,898 Upvotes on 3,494 Posts
Also..... depending on what those two circuits are.... you may find that breaker trips when both those circuits are in use as now you have two 20A circuits protected by one breaker.
Old 03-03-16, 07:22 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Was this a Square D QO or Homeline series panel? It sounds like a Homeline. If it was a Homeline panel, was the aluminum bus burnt, melted or damaged in any manner?
Old 03-03-16, 07:36 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
In solving the one issue the tech may have created another issue. Did they check the bus for damage. What circuit did the add the load to? You may now experience tripping on the second breaker.
Old 03-04-16, 03:42 PM
Roeboat109's Avatar
It is all square d and same size wire
I have been keeping an eye on it.Im down there by it every day
.The electrian that originally installed the system was a good friend.He is retired and I hate to ask him
