70 amp breaker and 1/0 aluminium wire
Old 03-03-16, 01:35 PM
N
Just wondering if a 70 amp breaker, will accept 1/0 wire? There are two breakers.
a Murray MP 70 amp breaker, and a Homeline 70 amp breaker. I've seen most product descriptions list the wires sizes between 8 AWG to 2 AWG, and actual Murray literature that shows wire size up to 2/0 AWG. I'm inclined to believe Murray, but wanted to see what any of you say. The wire is large, do to the distance from the main panel, and any possible future upgrades. Thanks for your help. John.
Old 03-03-16, 01:36 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
You can always pigtail down to a size the breaker accepts.
Old 03-03-16, 01:55 PM
P
Received 210 Votes on 178 Posts
Square D Homeline 70A is listed to take up to a #2. With #1/0 you can go larger than 70A. The Homeline 80A takes up to #2/0. What's your reason to go with just a 70A on #1/0?
Old 03-03-16, 02:44 PM
ray2047's Avatar
Pat asked:
Nilzlofgren previously explained:
Nilzlofgren, what is the distance?
Old 03-03-16, 03:31 PM
N
The distance is 240 feet. I have the wire, but haven't bought the breakers yet. I could buy 80 amp breakers, but Ive already received my permit. Not sure how critical of a change that would be. Guess I could call the inspector.
Old 03-03-16, 03:57 PM
Received 2,952 Votes on 2,664 Posts
1/0 aluminum is rated for at least 120A. You could use a 100A breaker with no issues.
As long as your breaker is under the ampacity of the wire.... the inspector should have no issues either.
Old 03-03-16, 04:46 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
Just remember that if the hots are upsized for any reason, like distance, the EGC must be increased by the same percentage.
Old 03-03-16, 06:51 PM
CasualJoe's Avatar
Received 163 Votes on 146 Posts
There are two breakers. a Murray MP 70 amp breaker, and a Homeline 70 amp breaker.
What kind of panel is this? A Murray breaker isn't UL Listed to be used in a Homeline panel and a Homeline breaker isn't UL Listed to be used in a Murray panel. If the inspector knows his stuff, you have a problem.
Old 03-04-16, 02:56 AM
N
The panel in the house is a Murray. The panel in the Pole barn is a Homeline.
