Decorative wood wall plates that aren't too thick?
Old 03-09-16, 05:44 PM
I like the look of wood wall plates (light colored oak preferably), but the Hampton Bay ones that Home Depot caries are too thick and prevent using power bricks.
GE makes ones that are a bit thinner than the Hampton Bay ones that at least let power bricks plug in, but power bricks still aren't flush and I worry they might come loose over time.
Does anyone know of a company that makes wood wall plates for the look, but that are thin with a metal back for support?
Thanks!
Old 03-09-16, 05:53 PM
ray2047's Avatar
I sounds like the receptacle isn't flush with the wall. If so you need to bring it forward.
Old 03-09-16, 05:59 PM
Post a picture so we can see what your seeing.
Old 03-09-16, 06:02 PM
ray2047's Avatar
http://www.doityourself.com/forum/li...rt-images.html Keep the width to 1000px or less.
Old 03-10-16, 04:47 AM
Tolyn Ironhand's Avatar
A quick search on google pops up a custom place (or two) that will make plates to your specifications. Search "wood outlet plate" It is about the 6 one down from the top. You could send them an e-mail to see how thick they are and if they can be made thinner.
I think a lot of wood plates are thick so they do not split or break.
Old 03-10-16, 06:11 AM
Plates
I prefer the wood-grained metal plates.
Old 03-10-16, 08:24 AM
Maybe use a decorator style (rectangle) receptacle instead of a duplex? The wide flat area should be enough to support the wall wart.
Old 03-10-16, 03:14 PM
Pics
With plastic wall plates it is flush:
Old 03-10-16, 03:17 PM
With GE wood plates
With the GE brand oak wood plates it isn't quite flush:
Old 03-10-16, 03:27 PM
Home Depot Hampton Bay
I returned them without taking a picture, but you can see on the Home Depot Web site that the Hampton Bay plates have a raised border. The outlets are flush with the lower inside, but the power bricks are very lose and some don't even stay plugged in with the raised border.
1 Duplex Outlet Plate - Un-Finished Wood-180DHB - The Home Depot
Old 03-10-16, 04:47 PM
ray2047's Avatar
They make one foot extensions for power bricks.
Old 03-10-16, 05:14 PM
Wirepuller38
Do you have a link for an example? Searching myself I didn't see any metal plates that look like wood.
Old 03-10-16, 06:58 PM
ray2047's Avatar
Old 03-10-16, 07:12 PM
Gunguy45's Avatar
Super Moderator
I'm late to the thread, but did you take a receptacle and put it in the plate to see how it fits? My old neighbor in VA, a Master Electrician, told me to loosen the screws to the box slightly and then use the plate screw to pull it up tight.
