Breaker/transfer switch question
Old 03-14-16, 11:51 AM
Good morning team,
Just researching transfer switches and have a quick question regarding wiring tandem breakers.
safe to assume each switch on the tandem gets wired to its own switch inside the transfer box?
Old 03-14-16, 11:56 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Please give more details including make and model number of your switch and where the tandems are. Normally there is only one transfer switch so I'm a bit confused by why you seem to be talking about more then one. More details on what you are doing please.
Old 03-16-16, 10:45 AM
Z
Received 116 Votes on 107 Posts
Agree with Ray, more details are required.
But if I understand your question, you want to connect a 240v load (double breaker) to your transfer switch. A 240v load has two wires (usually red and black, but could be black and white with the white wire taped to indicate hot). Those two wires would go to a similar double breaker on the transfer switch. The breaker on the transfer switch needs to be a double breaker (not just two single breakers*) and needs to be the same amperage rating as the one that was connected.
* Depending on your transfer switch, two single breakers may be able to be used with a handle tie in certain circumstances. See Ray's question above.
Also, to clarify, a double breaker provides the load 240v. A single breaker provides 120v. And a tandem breaker is two breakers that fit in the space of one and provide 120v to two separate loads.
(There are double tandem breakers too)
Confused yet?
