Sears compressor
Old 03-26-16, 05:13 PM
Yes, you can. 10 AWG is rated for 30A, so length doesn't matter. 12AWG will work with 30A as long as the load is a motor like your compressor. But, I feel safer with 10AWG and also safe when you decide to go for over 20A load later.
Old 03-26-16, 05:55 PM
Great! And thanks to all for the correct info. I am new to this forum. I have been building high end furniture and custom boats for 35yrs. An injury forced an early retirement. Maybe I can find a DIY forum to offer advice in my field as pay back for all the help I found here. Thanks again.
  #43
Old 03-26-16, 05:59 PM
ray2047's Avatar
You only need #12. This is a wiring exception to the usual rules. With motors you can match wire and receptacle to the motor amps. However there is nothing wrong with using #10 and a NEMA 6-30 plug and receptacle.
(Note that is not a dryer plug or receptacle. Dryer plugs and receptacles are 120/240 devices not 240 devices. You need 240 plug and receptacle.)
  #44
Old 03-27-16, 03:13 AM
You can use the #12 but may need a 25 or 30 amp breaker. Try the 20a first if you want.
I have a 6 hp 60 gal air compressor in my shop. I don't remember the amps but it's connected to a 20 amp 240 circuit and I've never had it pop the breaker. Mine is wired direct - no plug, if that makes a difference.
  #45
Old 03-27-16, 06:24 AM
Once I have the correct receptacle from the 30amp-2 pole mounted, can I pony a 15amp receptacle next to it? I was thinking on using a grount fault receptical. Make sense?
  #46
Old 03-27-16, 08:23 AM
Due cost, for now I'm going to stick to 20amp. After checking prices in my Grainger book.
  #47
Old 03-27-16, 12:30 PM
ray2047's Avatar
It should be okay to use the same for both.
  #48
Old 03-27-16, 03:42 PM
If you are talking about 15A 240V yes. If mean 120V GFCI, no.
Have you checked prices at a box store or electrical supply store?
Grainger in my experience has always been the most expensive place.
