3 Wire Solid State Variable Fan Speed Control Wiring Help
Received 0 Votes
Greetings, I have this variable speed control with Red, Black and Grey wires coming out. It must be connected to a 3 wire supply line, having Red, Black, and White and a ground wire. I'm not sure how to tie the two together, mostly do to the grey wire on the speed control. Will someone please set me to right here. Thanks. Links to photos are below. The third link is the supply.
2016-03-29_1455 - Docfletcher's library
2016-03-29_1456 - Docfletcher's library
2016-03-29_1457 - Docfletcher's library
That control is not a standard variable fan speed control. Did you get with a certain fan.... as part of a kit ?
TriVar Solid State Motor Controls
Received 0 Votes
It was offered as accessary item with AXC bath fan motor (Canada). Here is link to wiring diagram. The part about removing jumper is done. Continental Fan Manufacturing.
Where you see gray at the terminal block is actually the black wire of the supply line. ( There are no 3 wire plus ground with gray wire in them)
2016-03-29_2331 - Docfletcher's library
Are you bringing power to the control first and then a three wire cable from the control to the fan ?
Received 0 Votes
Well, what you have outlined in color is the 3 wire romex which I wired to the terminal block 1st. I can see grey (black) connection and red you have placed on the control. So now I need to bring power in. So I think I see now that would be tying in black and white wire to the outlet box for power. Is that correct? Thanks Don
Possibly a defective control.
I found an alternate diagram for the speed control and it matches what you have.
Received 0 Votes
Well I guess I'll have to climb back up into the attic and put the jumper back in and just use as single speed. The controller has been hanging around the house for a few years, never used it.
