Reload this Page >
Electrial Wiring Diagram Software - What type do you recommend?
Old 04-09-16, 11:43 AM
Hello,
What type of Home electrical wiring diagram software or online software can one recommend to use? I would like to draw a simple diagram and post my issue here.
I have a wiring issue with a 3-way dimmer switch and I think assembling the diagram would be better, since the photos are difficult to discern with the mess of wires that are in a gang box. I would appreciate any recommendations.
Old 04-09-16, 12:00 PM
Welcome to the forums.
I use the PAINT program almost exclusively. It comes with just about any computer.
You can also take pictures of the switch wiring and posting them here. http://www.doityourself.com/forum/el...-pictures.html
Old 04-09-16, 12:38 PM
ray2047's Avatar
Agree with Pete Paint is the easiest. Also do not show grounds. Grounds aren't needed and just clutter the diagram making it harder to read. I prefer to make the background gray so white wires show but if you use a white background gray wires for white are acceptable. (Both white and gray are code acceptable colors for neutral.)
You can also use paint plus a free program such as Gimp to insert images.
Old 04-09-16, 01:01 PM
Two things....
You can insert images directly into paint and I never considered using gray as a background color. Makes perfect sense.
Old 04-09-16, 01:51 PM
Most awesome, thank you for the info!
Old 04-09-16, 01:59 PM
ray2047's Avatar
I used Paint as a generic term for a type of graphics program. Mine doesn't have insert and the MS paint I'm familiar with in Windows 98 didn't either.
Pete, will modern MS paint also do transparency? You need that with insert (layer) so the background shows through around the image.
Old 04-09-16, 04:31 PM
Yes.... in windows 7 it does.
