Fluorescent fixture hookup
Old 04-12-16, 01:35 PM
I'm replacing an old 4' T12 fluorescent fixture with a new 4' T8. I'm not 100 percent confident about wiring this thing yet. Attaching some pics. Any help appreciated.Name:  20160412_114717.jpg
Old 04-12-16, 01:38 PM
New fixture
Pics wouldn't load first time. This is the new fixture. Looks like a push on connector on right - not sure how to deal with that.Name:  20160412_114842.jpg
Old 04-12-16, 01:42 PM
Re: new fixture
Hope this is ok way to do it
Old 04-12-16, 02:16 PM
Received 2 Votes on 2 Posts
Its hard to tell from the picture but the blue wires with the "push on connector" appears to be unrelated to what you are doing (maybe for running additional bulbs off the ballast?). The ballast has 2 wires tied up the left that are probably for power. You should be able to follow the wiring diagram on the ballast to connect it to your house wiring. If not, you will need to post a better picture of the wiring diagram on the ballast.
Old 04-12-16, 04:31 PM
pcboss's Avatar
Received 39 Votes on 34 Posts
The tombstones should have already been wired correctly. The only connections you should have needed to make were to the black and wire from the ballast to the building wires and the building ground.
Old 04-12-16, 04:36 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
Maye sure you use a bushing/connector for this hole if you are installing a cable.
Old 04-12-16, 06:36 PM
Ballast
I asked a contractor who happened to be in the store if I needed a romex bushing and since it's inside the house, he said no.Name:  20160412_171232.jpg
Old 04-12-16, 06:48 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I'm confused. Your first fixtures seem to be single tube but your picture of the ballast is a two tube ballast.
Old 04-12-16, 06:52 PM
'Fancy' wiring
The thing that's throwing me off is the extra connectors they put in there...maybe they just needed more wire?Name:  wiring.jpg
Old 04-12-16, 07:25 PM
That is confusing. The diagram shows two lamps, but it is a single lamp fixture...far as I can tell.
Old 04-12-16, 07:37 PM
ray2047's Avatar
Is that a new ballast you bought? Does it say for both single or double tube? I can tell you how to wire it by capping and not using one of the wires but not sure if it will work.
Name:  Universal B232IUNVEL-A Wiring Diagram.GIF
Old 04-12-16, 08:17 PM
pcboss's Avatar
The fixture is too narrow to install over a ceiling box.
A cable clamp is needed.
Old 04-12-16, 10:53 PM
4' 1 Lamp Strip
This is a "4' 1 Lamp Strip" - as it says on the outside of the box which is too narrow to hold anything else, mounted to a wall.
The ballast came installed with the strip.
Not sure what you mean, "insulate to 699 volts".
Old 04-13-16, 12:10 AM
ray2047's Avatar
Ignore the writing. That was just on the diagram I pulled off the internet. I have to say I thought you were converting a T-12 to a T-8 by switching out the ballast. I just read too fast. Okay I looked carefully at the new fixture and is that a black and white wire on the left side of the fixture? If so that goes to house power.
I'd ignore the connector on the blue wires on the right.
