Question about Strip Length for Wire Nut
Old 04-16-16, 10:50 AM
I just bought 3M Performance Plus wire nuts. Most of the instructions that I've seen say to strip the wire 1/2-5/8 in. I noticed that these say 3/4 in which seems long to me. Is it okay to use the normal 5/8 in? It's #14 wire.
This is kind of an unrelated question, but is it bad if the copper is rough? The switches that I'm installing have built-in pigtails, not screws on the sides. I've removed the connections and straightened the loop with my linesman pliers. In doing so, it seems that the copper is no longer smooth. I wasn't sure if that makes the conductor brittle. I have some extra length, so it may be better to re-strip the wires.
Old 04-16-16, 11:44 AM
Tolyn Ironhand's Avatar
Yes, That should be fine as long as the wires are contact with each other.
The wire does not need to be smooth to make a good connection.
Old 04-16-16, 12:11 PM
I have a dumb followup question. I am probably overthinking. The new switch that I'm installing has a pre-stripped pigtail. It says that no stripping is required. The stripped length is 7/16". I have my wires at 5/8". Do they need to be the same length? If not, how do I connect them? Should the ends be even with each other? Is it okay for insulation to touch the bare wire? I've included a picture so you can see what I mean! Thanks in advance for your help.
Old 04-16-16, 12:26 PM
Yes, the wirenut will grab the wire then.
Yes, The insulation is always touching the wire. It is covering its entire length.
Old 04-16-16, 01:05 PM
Handyone's Avatar
As Tolyn said, yes. Just get in the habit of trimming wires a little when doing your connections.
I strip solid to solid wires the same length always.
For solid to stranded, especially small stranded wires, I strip the stranded wire a little longer.
Forgot to add: You will go far being conscientious like this
Old 04-16-16, 01:40 PM
pcboss's Avatar
Just match the wires at the stripped end. The insulation touching is not an issue.
Old 04-16-16, 05:01 PM
Just as an aside here..... the manufacturers are very thoughtful to pre-strip the wires for you but they are never stripped far enough.
Old 04-16-16, 06:32 PM
I agree 100%
Old 04-16-16, 06:38 PM
ray2047's Avatar
Maybe wrong but when i have stranded fixture wire smaller than #14 I strip off about an inch of insulation and wrap it in a spiral from bottom to top of the house wire.
