Outdoor outlet fail
Old 04-19-16, 11:57 AM
Outdoor outlet fail
Hello All,
I uninstalled my outdoor outlet so I could install it inside of an outdoor cover. I shut off the breaker before the install.
After the install was complete I flipped the breaker back in and plugged something into the outlet but no Bueno! I hate DYI stuff whe. You run into stuff like this! Why can't everything go ok?!
I hooked the multimeter to an outlet in the same circuit and it gets 120 volts. I tried the outdoor outlet and it's dead. I deinstalled the outlet and tried the cables only and still dead.
Did I possibly break a wire? The other wall outlets in the circuit work.
I hate failing
Old 04-19-16, 12:14 PM
I
Received 42 Votes on 40 Posts
Is this receptacle downstream of a GFCI receptacle which may be tripped off? Try the RESET and TEST buttons on any GFCI receptacles on this circuit.
You only fail when you give up. Solving a problem takes determination, not perfection.
Old 04-19-16, 01:11 PM
Thanks for the encouragement!
I won't give up.
None of the downstream a are GFCI, all are standard and working.
Old 04-19-16, 01:19 PM
Received 85 Votes on 75 Posts
Maybe you misunderstood or mistyped but Ben asked whether any receptacles upstream of this were GFCI - you wrote than none downstream were.
If this is outside, it should have GFCI somewhere - either at the breaker or, more commonly, at a GFCI receptacle upstream.
Old 04-19-16, 01:59 PM
I am not finding a single GFCI on the circuit either upstream or down. The outlet is outdoors but it isn't GFCI. Name:  IMG_5932.jpg
Old 04-19-16, 02:33 PM
Here are some pics showing the path of the flow.
There is one outlet that is on the opposite wall in the kitchen that is also in this series, but is not GFCI.
Old 04-19-16, 02:35 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need to look everywhere inside and out, attic, bath, kitchen, garage and behind something you haven't moved in years. Do you have GFCI breakers.
Old 04-19-16, 02:39 PM
Received 53 Votes on 48 Posts
Those outlets over the kitchen countertops by code needed to be protected by a GFI.
Does the breaker look like all the rest of the breakers of does it have a red push button on it?
Old 04-19-16, 02:57 PM
SOLVED!!!!!
I will post write up shortly!
Old 04-19-16, 04:13 PM
pcboss's Avatar
Received 62 Votes on 54 Posts
receptacle should not be fed from the kitchen. I bet it comes from a bathroom or garage circuit.
Old 04-20-16, 04:20 AM
I found a GFCI fed off of another breaker that was the culprit! I pushed the test or reset button and I was back in business!
I am confused as to how a GFCI on another breaker could impact another breaker.
Thank you all for the help! 9 hours it took for me to start and finish this!
Old 04-20-16, 11:52 AM
ray2047's Avatar
Sounds more like you guessed wrong on which breaker the receptacle is on.
