Drill bit for drilling through outside wall for wiring?
Old 04-24-16, 11:31 AM
I need to drill a hole through the outside wall for a 12V DC power for a CCTV cam.
The cable is about 4mm. I am trying to avoid a big hole. I figured 11/64 would be a good diameter.
What type of drill bit should I get? I know larger installer drill bits have a long shank.
So, I am not sure if something like this would work? (I figured I need 8" of drilling)
http://www.amazon.com/Extra-Long-Dri.../dp/B00B89OCDS
Old 04-24-16, 11:34 AM
Received 482 Votes on 452 Posts
The smallest diameter "long bit" I use is 1/4". Usually works perfect for a small 2 conductor cable or even Cat5 cable.
Old 04-24-16, 11:47 AM
Received 1 Vote on 1 Post
You are just drilling through wood, drywall, wood/vinyl siding correct? No brick or concrete block? Those materials would require a masonry bit....
Old 04-24-16, 11:56 AM
yes, drywall (insulation) plywood, wood siding
Old 04-24-16, 12:25 PM
Received 7 Votes on 7 Posts
The high speed steel bit will work fine for these materials.
Old 04-24-16, 12:27 PM
Keep in mind..... when you drill blindly thru the wall..... there is "stuff" in there. Stuff could be ducts, wires, pipes, etc.
Old 04-24-16, 12:40 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I always preferred a bell hangers drill bit. The hole in the end allows you to pull a string back through which on hollow walls makes is easy to just pull the wire through with out blind stabbing for the hole in the wall on the other side.
