Wire color question
Old 04-29-16, 01:42 PM
Wire color question
Ian going to wire a branch circuit from a sub panel in a barn to a separate, detached shed. Will only run one branch circuit (20amp) to a disconnect in the shed. Plan is to run #10 wire in buried conduit. Distance is about 150ft.
A quick look at a big box store shows a 500ft roll for $62.
Buying by the foot, cost is $.49/ft.
I need to run 3 wires. Cost would be
3 rolls - $186 with plenty of wire left over
3x200 ft - ~$300
I could save a few bucks by using a single roll of wire for two runs. That would make the wires the same color. I could easily mark them with tape at both ends.
Any problem with this? I just hate to throw away the money and have 900 feet of left over wire I do not need.
Old 04-29-16, 05:07 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
The #10 needs to be in the proper colors. It is too small to re-identify with tape or paint.
Old 04-29-16, 05:26 PM
Received 16 Votes on 14 Posts
Old 04-29-16, 05:54 PM
Received 517 Votes on 487 Posts
Since the wire will be used outdoors.... it must carry the THWN rating for waterproof.
Old 04-29-16, 06:18 PM
Tolyn Ironhand's Avatar
Received 74 Votes on 66 Posts
Wire by the foot is always over priced. Check around at other stores that sell smaller spools. I know Menards stores sell wire in smaller quantities.
Old 04-29-16, 06:23 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The BigBox store copy writers often in ads misidentify THHN/THWN as THHN. As suggested just make sure befor buying.
Old 04-29-16, 08:14 PM
@Astuff - thanks for the link. Seems to be what I need. Just need to find it in #10.
@pcboss - that's what I was afraid of. Hopefully I can find a package with 3 wire colors. If not, guess I will have to overbuy.
I will also check some local electrical supply stores. They may have something.
@ray2047 and pjmax - Yes, I know I need THWN. I was in Lowe's today looking at the actual wire. All the Lowe's terminology states THHN. However, the wire itself and the packaging all indicates it is also THWN. I really want to save a few $$$, but won't compromise safety. Plus, if you don't have the time/money to do it right the first time, where will you find the time/money to re-do it the right way?
Thanks for the info everyone.
