Hot tub and AC compressor don't get along
Old 04-30-16, 06:06 AM
I have my hot tub placed about 6 feet from my AC compressor and at time when the compressor is running it causes a fault in the hottub and it will have to be power failed to recover. The tub is a 2014 Jacuzzi j325 running on a dedicated 120 volt 20 amp circuit. I had a 22 year old Hot Springs tub there before also running the 120 volt line and never had a problem.
Of course that was running mostly old relays and would be much harder to trip. I want to now run a 220 line out to the tub and the power will run very close the the AC compressor and to the power cord for the compressor.
Anything I can do to lessen the impact of this move?
Old 04-30-16, 10:12 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
What impact. Your post doesn't really make much sense. Can you try again to explain your problem.
Old 04-30-16, 10:54 AM
With the current set up when I run my ac it sets a fault on my hot tub. Hot tub tech has no idea why but I think it is caused by some sort of interference from the AC. I am going to convert the tub to 220 and would like to reduce any chance of interference from the ac if possible. The 2 220 volt lines will be very close together .
Old 04-30-16, 11:50 AM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
The most likely cause I can see is a momentary voltage drop as the compressor starts. A much less likely cause could possibly be a voltage surge or spike caused from the compressor or condenser fan motor starting.
Old 04-30-16, 12:35 PM
pcboss's Avatar
Received 30 Votes on 26 Posts
So the A/C is causing the gfi for the tub to trip?
Old 04-30-16, 12:47 PM
No the Gfci does not trip. I get whats called a watchdog fault . It thinks something is wrong, maybe overheating or something else and heaters and pumps turn off but power remains on the control panel.
Old 04-30-16, 01:29 PM
pcboss's Avatar
Do you still have the issue if the A/C doesn't run?
Old 04-30-16, 02:20 PM
No, without the AC it runs fine. But summer is coming and trying to fix before issues surface again. I am hoping that going to 220 will help. Anything I could do to provide better shielding when running my new wires?
Old 04-30-16, 02:28 PM
Received 23 Votes on 19 Posts
I suspect the Hot tub is reacting to a voltage drop as earlier stated by CasualJoe. Switching to 240V from 120V will help if it is a voltage drop problem.
Old 04-30-16, 02:39 PM
Thanks. I will report back after I switch and if it ever gets warm enough to use the AC here.
Thanks again.
Old 04-30-16, 02:41 PM
ray2047's Avatar
Tech note: You will be running 240 volts to the Spa not 220 volts.
Old 05-01-16, 07:02 PM
CasualJoe's Avatar
Shielding of the branch circuit wiring is not a problem. Just use approved branch circuit wiring methods and materials used elsewhere in your house which is probably NM cable (aka Romex).
Old 05-01-16, 10:54 PM
It sounds to me like the A/C is causing a voltage sag that makes the hot tub controller think that something is internally wrong with the heater.
I would try a different brand of controller.
Check the service drop to the house to be sure is is large enough. My house has a 200 amp breaker, but the power company left the old 100 A drop because I didn't have a central air conditioner. I still don't. But maybe your service drop is undersized.
Your pole transformer might also be undersized.
Also check that the neutral connections are good and tight. A high-resistance neutral on the A/C or the service drop can cause this with a 120 V controller.
Old 05-01-16, 11:16 PM
ray2047's Avatar
Usually no neutral connection on the outside A/C.
Old 05-02-16, 03:46 AM
A different controller would be up to the hot tub company as tub is still under warranty. I will go to 240 ;-) and see what happens after that. It's a pain in the b... but at least it only happens in the summer so no chance of freezing. Thanks
