How to measure Voltage without cutting wire?
Old 04-30-16, 01:56 PM
Question How to measure Voltage without cutting wire?
Is it possible to measure Voltage without cutting a wire. No needles penetrated the wire))
Old 04-30-16, 02:43 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No. Why do you need to do this.
Old 04-30-16, 02:47 PM
Received 62 Votes on 57 Posts
Any wire that I have seen starts and ends someplace, and you should be able to take a reading at one of those points, but you need to be more specific.
Old 05-01-16, 06:38 AM
GregH's Avatar
Super Moderator
Received 13 Votes on 13 Posts
Are we answering your test questions for you???
Old 05-01-16, 08:03 AM
Received 11 Votes on 11 Posts
yes, but it will cost lots of $$.
Old 05-01-16, 11:05 AM
pcboss's Avatar
Received 32 Votes on 27 Posts
I would say yes, but you need to know the load on the circuit.
Anyone want to play along?
Old 05-01-16, 04:30 PM
Received 18 Votes on 17 Posts
If you have a constant load with known value (light bulb, heater coil, etc..), you can measure current with a clamp meter and calculate voltage from it.
I think this is what pcboss is suggesting.
But, this can have pretty big error because a clamp meter is not very accurate. Error of few hundreds mA can mean several volts of error.
The equation is
V=P/I
Where V is volt, P is power in W, I is current in A.
Old 05-01-16, 10:18 PM
pcboss's Avatar
We have a winner.
Old 05-02-16, 05:43 PM
Becomes tougher, but still possible, when the load is zero.
