Electric door strike-DC to AC
Old 05-11-16, 10:48 PM
H
Hey there I have a 24V DC electric door strike and was wondering what might be the cheapest way to power it. There is only 120v AC. Thanks
Old 05-11-16, 11:04 PM
F
Received 36 Votes on 28 Posts
Use a 24 volt DC wall wart supply that has at least a 750 milliampere output. Some door strikes will allow for either AC or DC in the 10 to 24 volt range. Generally the AC models give a loud buzz (alert to push on the door) whereas the DC models are silent.
Old 05-12-16, 11:19 AM
H
Do they make those so you an tie an 18/2 wire to it.
Old 05-12-16, 12:30 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I don't understand what you mean. You would just splice the wires.
Old 05-12-16, 12:56 PM
Received 30 Votes on 29 Posts
I think he means an adapter with screws and not just two wires coming out
Old 05-12-16, 02:02 PM
F
Yes, they make wall warts with screw terminals. Sometimes a bit harder to find and usually a bit more expensive than ones with just "flying" leads, but definitely available.
