Basement wiring and lighting
Received 0 Votes
My basement was previously wired for 6 lights. Now that I am finishing the basement 2 of those lights are no located in unfinished (utility areas). I would like to have lights on switches in these two rooms.
Instead of having to rewire all these (3 way) and save a ton on 250 feet of romex for two lights, can I simply remove the two fixtures in these rooms wire nut the wires together and close up the box with a plate leaving the wires connected so they run to the next light?
In order to wire in the new switches and lights for the utilities rooms I have currently have two 20 amp outlet runs in the basement. Each has 8 outlets on it. Can I add onto these (1 light light and switch for each) and run a line from the last outlet to the "new switch" in the utility room and then up to a new receptacle box for the new light? Or do lights have to be on independent circuits than the outlets?
Thanks
Thanks
Laundry, kitchen small appliance, and bathroom receptacle circuits cannot have lights (or anything else) on the same circuit. Otherwise it's ok to mix. I usually avoid it to avoid having the lights go out if something plugged in blows a breaker, but it's not against code.
Wiring it as you describe will give you a neutral in the switch box, which is now required.
