Manufactured Home light switch replacement
Received 0 Votes
I am trying to replace a light switch in my manufactured home. When I pulled it from the wall, I noticed 3 sets of wires attached to the old switch. After doing some research, I found I need to use a "workbox" as a replacement to go into the existing opening. I need to know how to attach the existing 3 sets of wires to my new switch. Attached are images of the old switch and the new one I am replacing it with. Thanks.
Hard for me to see but best guess is one cable is power in (line). One cable is unswitched power out (load) and the third cable is switched power to the light. If I am correct:
- All whites wire nutted together.
- Black of switched power to the light to one side of the switch.
- Black of power in and black of unswitched power out connected to a pigtail.
- Pigtail to other screw on switch.
Ray's diagram is probably correct. However it's unclear which switch you purchased.
The pictures you posted are two different switches, and that matters.
The switch on the left (front view) is a single pole single throw switch, the switch on the right (rear view) looks like a 3-way switch.
You need the switch on the left, A SPST. It will have 2 brass colored terminals and a ground screw only. It will also be marked "top" on the frame.
Usually in a box of that type (stab) there are only two cables. I'm not sure you can fit a standard switch in that box with three cables. It will be tight.
Received 0 Votes
The image I posted of the new switch was pulled from the internet. The back side is correct and represents the new switch I bought. Here is the actual front view of the switch.
So I guess the question is: do I have the right switch, or do I need to get a Single Pole-2 way switch?
Devices used in manufactured homes are not the same as the ones used in a standard stick built house. They are self contained devices and do not require a box. The switch you are installing does require a box.
To properly install the new switch a remodel plastic box will need to be installed. The cables will be spliced in the box as Ray showed in his diagram and then the switch will attach to the new box. The cables/wires appear to be rather short so they might need to be extended.
Your other option is to purchase a self contained switch like this: Pass & Seymour Almond Self Contained Rocker Wall Switch | Mobile Home Parts Store
Your other option
Your other option
do I have the right switch....Single Pole-2 way switch?
Received 0 Votes
That is what I meant, in regard to the work box. I've seen several tutorials showing the work box as a replacement where the old switch box was. I picked up one just like the image you posted.
