Breaker that runs subpanel is tripping
Old 06-12-16, 03:19 AM
O
I ran some 10/3 wire from a 30 amp 240 v breaker at main panel to a subpanel. subpanel with ground bus. red and black to hot busses, and neutral to neutral bus. the previous owner of the home had run some 12/2 to this panel, and just ran one hot wire in, and had the neutral returning. The ground wire was wound together with all the grounds from the three circuit breakers in the subpanel. this subpanel is now wired exactly as in the diagram on this forum, for a subpanel in the same building, with no attachment to ground rod. when i switch on the breaker at the main panel it shorts out. there was a spark inside the main panel when i switched on breaker. the 10/3 wire does not seem compromised, nor were there any contacts between ground wire and hot bus in the main panel. what is the problem? is subpanel faulty?
Old 06-12-16, 03:35 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Disconnect wires at sub panel and see if the breaker pops now. If not you have something wrong in sub but if pops than in wire.
Old 06-12-16, 03:46 AM
chandler's Avatar
Received 6 Votes on 6 Posts
It wouldn't hurt to post pictures of the inside of your two panels showing how things are connected. http://www.doityourself.com/forum/el...your-post.html
Old 06-12-16, 04:05 AM
O
it still pops. i will re-examine the wire and rerun it if needed. thank you! and thank you to chandler too
Old 06-12-16, 05:57 AM
Geochurchi's Avatar
Received 81 Votes on 76 Posts
Better off using a multimeter to find the problem then testing by using the breaker.
Old 06-12-16, 10:06 AM
pcboss's Avatar
Received 92 Votes on 79 Posts
Did you remove the old feed to the panel?
