Help confirming generator cord
Old 06-14-16, 07:37 AM
G
Question Help confirming generator cord
My house has an interlock kit installed and a generator inlet outside with what appears to be a 50 amp CS6364. My Champion generator has a L14-30R receptacle, I understand this is only 30 amps but it should meet my power requirements. So I think I'm looking for a CS6364 to L14-30P cord which seems to fairly uncommon (I did find a few such as this: https://www.amazon.com/Conntek-Trans...dp/B005HYY2M6/ ). Are there any issues with this setup that I should be aware of, or a better way to feed my panel with this generator?
Thanks.
Old 06-14-16, 07:47 AM
Received 1,403 Votes on 1,298 Posts
Better way.... not really. You need a cord with different ends.
That cord in your link will work. I make my own as I have the cable on a reel and the caps loose.
I would highly recommend checking that cord after it is connected and powered before doing a transfer. Best way to check it is at the transfer breaker inside the panel.
Old 06-14-16, 08:01 AM
G
Thanks for the input. How would I check the cord?
I could have an electrician come out and replace the CS6364 receptacle, that would be quick work but would likely cost as much as buying the $150 cable. Glad the cable is a viable option.
Old 06-15-16, 11:33 AM
Z
Received 176 Votes on 157 Posts
The benefit of leaving the receptacle as-is if you ever decide to upgrade your generator, you are all set for a 50A feed.
I think Pete was suggesting for you to wire up your new cord, plug it in and turn on the generator.
Open the breaker box and using a meter, check at the transfer breaker (still off), that you have 240v between H-H, and 120v between each Hot and Neutral. You'll want to find out about any miswiring before you flip the transfer switch.
Old 06-15-16, 01:31 PM
G
Thanks for the input, expensive cord will be ordered!
Old 06-15-16, 01:57 PM
I
Received 44 Votes on 42 Posts
Replacing that flanged 50A inlet with the 30A version would be a quick DIY job. Materials would be much less expensive than cable adapters.
