Outlet/switch combo on my furnace
Received 0 Votes
There is an Outlet / Switch in a single box attached to my Furnace.. there is a separate emergency shutoff switch in the hallway for the furnace.. what is the attached one for and can I use it for a dehumidifier or should I run a new circuit?
Thanks
Thanks
By code you need a service switch AT or within direct sight of the equipment. Many times a second switch is installed at the entrance to the furnace room or at the top of the stairway leading to the basement.
Normally that receptacle is used for a condensate pump, humidifier or service light.
A dehumidifier is usually plugged into a GFI receptacle in the basement.
I would use that outlet for the dehumidifier ,although all new receptacles in a basement are required to be GFCI that is an existing receptacle,I don't know of a requirement that a dehumidifier must be plugged into GFCI
There is no requirement that a dehumidifier be plugged into a GFI receptacle but general use receptacles in a basement are supposed to be of the GFI type.
Since the furnace won't be running when the dehumidifier is.... that receptacle should be ok to use.
