Power Converter Question
Old 06-25-16, 05:42 PM
C
I have a power converter that plugs into a car cigarette lighter and it has these specifications: Peak Surge Power 500 watts, AC Output Voltage 110+/-5V.
I have an electric bike batter charger that has these specifications: Input 100-240V~ 60/50Hz 2.5A
So the question is, can I use the electric bike charger by plugging it into the power converter? I have two of thee chargers and the power converter has capacity for two plugs. Can I plug both? One? Or none?
Old 06-25-16, 06:14 PM
F
Welcome to the best DIY forum on the Internet.
Your power converter, more properly called an INverter, probably has a continuous output of 250 to 350 watts. At 110 volts your bicycle charger will be taking about 275 watts. It should be okay for one charger but definitely not for two.
One caveat, your inverter most likely has a "modified sine wave output" and this might cause the bicycle charger to overheat so watch it carefully and if either the inverter or the charger show any sign of overheating you should discontinue use.
Old 06-26-16, 05:55 AM
C
Thanks Furd!!! Will call it an inverter moving forward
