Cables coming out the side of my house
Old 07-07-16, 09:37 AM
G
Hi all again.
I have a question. On the photo below you'll see an electrical thing coming out from my siding.
Is there a way to know what this is and wether I can remove it or not?
Thanks!
Old 07-07-16, 09:46 AM
Received 1,342 Votes on 1,240 Posts
Looks like an old phone connection block.
Was it mounted up and is now hanging ?
Looks like writing on the cover... what does it say ?
Old 07-07-16, 10:18 AM
pcboss's Avatar
Received 105 Votes on 91 Posts
Looks like phone wiring to me too.
Old 07-07-16, 11:23 AM
P
Received 125 Votes on 99 Posts
What's on the back side of that wall? Can you see anything that may have been hooked to?
Old 07-07-16, 06:13 PM
G
Thanks.
Below I'm sending 3 more photos.
On the other side of the wall there's an electrical outlet, but it's not aligned ( the outlet is much lower and to the side).
Yes. It was mounted up, but I unscrewed it. So now it's hanging.
Thanks in advance.
Old 07-07-16, 06:21 PM
G
More photos:
Could it be the alarm system?
If it is, do you know if it's low voltage?
Old 07-07-16, 06:29 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
As you can see it clearly says "Bell System" on the cover and the wires are obviously telephone cable. It is exactly what every one has said it is. It is a phone connection box.
Old 07-07-16, 08:26 PM
I am extremely puzzled here. Normally the phone line from the pole comes down the wall outside the house, connects to that grounding block and is then sent inside to your phones.
The phone company cable drop is that heavy black cable and comes out of the wall. There is a solid ground wire and the D station quad cable. It's almost like the house was sided over the cables.
Old 07-07-16, 11:40 PM
pcboss's Avatar
Definitely an old lightning protection block for phone lines.
Old 07-08-16, 08:20 AM
P
The original wires are probably run down on the outside. I got a feeling the house was resided with vinyl and just the block was brought to the outside so not to cover it up.
