Converting Dayton motor voltage
Received 0 Votes
I'm new to this forum and am electrically challenged.
I have a Dayton Electric motor
Model: 5K122-C
Motor ref: M62056-C 0B
H.P.: 1/2
Volts: 115/208-230
Phase: 1
It is currently wired to run on 220 and I need to convert it to 110. I've opened up the wiring plate and was expecting to see a diagram... sadly, there was none.
There are 7 wires coming out of the motor all numbered on brass tags:
Wires: 1,2,3 are all Green
Wires: 5,6,7,8 are all White
Currently:
wires 1 & 8 go to the Black wire
Wire 6 goes to the Red wire
Wires: 2,3,5 terminate together
Wire 7 Terminates
How should I re-wire this to a 110v plug?
Model: 5K122-C
H.P.: 1/2
Volts: 115/208-230
Phase: 1
Currently:
Wire 7 Terminates
Welcome to the forums.
I don't see a C version but I do see an L version. The wiring should be the same. See if this diagram makes sense.
I'm still looking. This diagram doesn't appear to be similar to your motor.
Received 0 Votes
Thanks Pete. Yeah, It doesn't really tell me what to do with my #2 & #6 wires. That said, maybe I can make some educated guesses based on the 208-230 diagram. What’s the worst that can happen?
