Electrical Outlet/Adapter/Converters
Old 07-10-16, 11:36 AM
Picked up a Taylor Soft Serve machine today, Model #290-37, and the plug for it looks like this.
[ATTACH=CONFIG]68286[/ATTACH]
(250v 30a)
I have an outlet in my house that looks like this.
[ATTACH=CONFIG]68288[/ATTACH]
Is there an adapter that can be used to modify the outlet? Would I need to have an electrician come out and install a new outlet? Or is there another alternative?
Old 07-10-16, 12:04 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Welcome to the forums!
Your current outlet configuration is a 125/250 30 amp outlet. It is not a grounded circuit. Shut off the breaker/remove the fuses to turn off the circuit and look to see if there is a ground available.
Old 07-10-16, 12:08 PM
Will do, off to work now, will update tomorrow.
Old 07-10-16, 12:10 PM
Received 31 Votes on 27 Posts
You do mean no neutral avalible, not ground right Toyln?
Old 07-10-16, 12:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No, he meant no ground. That is an old style dryer receptacle that used the neutral for ground. The plug on the new machine needs a receptacle with a ground and no neutral.
Old 07-10-16, 06:22 PM
Received 18 Votes on 17 Posts
Is that plug really 30A ? Looks like 240V 15A plug (NEMA 6-15) to me. 30A one has wider spacing.
Assuming your existing outlet is wired correctly, you can replace outlet with one matching your plug and use neutral wire as ground.
If it is powered from a subpanel, neutral wire will have to be moved to ground bus bar.
Don't think there is any adapter for that because technically it does not have ground and would be illegal to use neutral as ground except on some special cases like is old dryers or ovens.
If you don't know how, best to call electrician.
Old 07-10-16, 06:46 PM
ray2047's Avatar
No, by code #6 and smaller ground must be factory green or bare.
Very good question that needs to be answered. What is the full load amps of the machine. What breaker size does the manufacturer recommend.
