AC mini split wire size question
Old 07-15-16, 06:28 PM
I'm doing the wiring on a mini split AC unit. I thought it was going to be 15 amp breaker 120v with 14 awg so I went out and bought everything and ran it before the unit showed up but now I'm not so sure.
Below is whats on the plate of the outside unit:
fan motor load (Indoor/Outdoor) .3A / .7 A
Compressor load: 15 amp
minimum circuit ampacity 20 amp
Max fuse 30 amp.
I'm sure I need to swap out the 15 amp breaker with a 20 but do I need to run 12 awg instead of 14?
Thanks!
Old 07-15-16, 06:32 PM
Received 345 Votes on 323 Posts
Unfortunately yes. You'll need to replace the #14 with #12 and use a 20A breaker.
Just so you are aware..... most split units require a three wire cable plus ground between the condensor and the evaporator inside. The two wire feed goes to the outside unit.
Old 07-15-16, 06:36 PM
Crap...... Ah well.
Yes I've already got the control wire for the inside unit. It only required 16awg and I bought 14 because that was easier to find so I'm better than good there
Thanks for the fast reply PJ.
Old 07-16-16, 07:01 AM
Received 12 Votes on 11 Posts
Since it is an A/C unit with a stated MCA you may be legal to use 14 gauge wires with a 30 amp breaker. Don't know what the Canadian rules are. Give your inspector a call.
Mod Note: the minimum circuit ampacity calls for a 20 amp circuit. The #14 is too small.
Old 07-16-16, 06:05 PM
CasualJoe's Avatar
Received 22 Votes on 17 Posts
Yes, the wiring needs to be replaced with #12, but I think I'd use a 30 amp breaker.
Why would a 3 wire cable plus ground be needed for a 120 volt unit? I've never wired one of these and want to learn. Have been thinking of replacing a through-the-wall heat/A-C unit with one.
Old 07-16-16, 08:06 PM
The power goes to the condensor outside. The inside unit actually does the controlling.
The power goes inside on white and black and out on the red for the compressor.
Old 07-16-16, 08:28 PM
OP is in Canada so I questioned whether different rules applied. Used to be OK here before 2009. CEC Table 2 shows 20 amp.
