Ground metal junction box?
Old 07-20-16, 08:21 PM
P
Hello!
I'm redoing a room of mine where I'm taking out the single light and adding recessed lights along with adding more outlets. Adding the outlets is not the confusion here. I plan to run a wire from each of the new lights (2 total) into the new junction box and splice the wires together. My question is, do I need to attach the ground wires to the junction box via the ground screw? I plan on doing all the electrical work (I'm 17 ) myself and I want to make sure I'm meeting electrical code.
Thanks!
Old 07-20-16, 08:40 PM
F
Received 35 Votes on 27 Posts
If you use a metal junction box it MUST be properly grounded. If you use a plastic box then (of course) there is no place for a grounding conductor and grounding would make no sense as the plastic is an insulator.
Old 07-20-16, 08:47 PM
P
That's what I figured. I'll make sure to ground the box. Thanks!
