Single location switch (extra circuit in box)
Old 07-22-16, 10:26 AM
Replacing an existing single location switch with a GE Smart Switch. I've installed multiple in my home but this is the first that has an additional circuit in the box.
Image below shows the switch connections. All three wires entering the switch are black. Two use the push connections in the back of the switch while the third wire (removed in picture) is attached to the side terminal.
I'm assuming the two circuits that utilize the push-in connections are line and load for the switch light. Any ideas about the presence of additional circuit and its typical use?
Also assuming that once I positively confirm the line I will have to pigtail it with additional circuit prior to installing new switch. Anyway, just wanted to confirm your thoughts.
Thanks.
Old 07-22-16, 08:48 PM
A few searches and quick test of the circuits for easy solution. There was one hot and two load circuits. One was controlled by the switch and the other always on. Added a pigtail for the continuous load.
Switch installed.
Old 07-22-16, 09:15 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Good Job! And remember just say no to backstabs. They are less reliable.
Old 07-23-16, 11:04 AM
Thanks Ray! Advice taken as always.
