Wiring problem- track lighting to bx cable
Old 07-22-16, 11:22 AM
client had removed a track lighting unit wired into a break in a bx cable, I connected black to the two blacks and white to two white,Name:  IMG_3380.jpg
Size:  34.2 KB plus ground, and dimmer switch blew out, replaced it with new one for LED bulbs and same thing happened, lights stay on after blowout, just no control. My electric skills are limited, can anyone tell me how to rectify this? Have a pic of the area and wires but can't seem to post it here.but can send if interested, Thanks in advance
Old 07-22-16, 11:56 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
What is the wiring at the switch? If it has a black and white wire on it you connected it wrong.
Step back further and give us another picture of the connection.
client had removed a track lighting unit wired into a break in a bx cable... My electric skills are limited
Then for liability reasons you need to tell him to call an electrician. Nothing in the picture looks right.
Old 07-22-16, 03:42 PM
Received 344 Votes on 322 Posts
You've run into a switch loop. One of those cables is the supply.... hot and neutral.
The other cable goes to the switch.
You're going to need to identify the hot wire/neutral cable.
Old 07-22-16, 08:54 PM
Received 12 Votes on 11 Posts
You have a mess as that also needs a proper metal junction box and connectors for the cables.
