Making use of dead hot tub wire
Old 07-22-16, 09:46 PM
bish80's Avatar
Just spent last weekend deconstructing a hot tub. Used a sawzall and circular saw, forgot to wear long sleeves and now I look like I have the plague and man does it itch. Anyway I have this beautiful (what looks to be size 6) wire running to a great place to put an outlet. Can I just just swap out the breaker with a 20amp and throw a GFI on the other end.
As always, thanking you in advance.
Scott
Old 07-22-16, 10:18 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Not if it's a wire but yes if it is a cable and you have a black, white, and bare wire in the cable.
Old 07-23-16, 12:58 PM
pcboss's Avatar
Received 92 Votes on 79 Posts
You could also install a small panel if needed. The existing conduit would need to terminate in a box. A gfi could be installed if you have individual conductors in conduit. You would need the weatherproof in use cover and a weather resistant GFI.
