Fan motor with and without capacitor
Old 07-28-16, 03:01 PM
sgull's Avatar
Received 11 Votes on 10 Posts
A small walk-in freezer where I work has dual evaporator fans in the unit. One of the fan motors seized up and needs to be replaced. Searching for replacement I found the same make and model number, and the picture of the replacement looks like a match for sure but it has a capacitor attached whereas my seized motor has no such attached capacitor. Does that mean I probably cannot use that particular replacement motor? Any comments appreciated.
Link to replacement motor here: https://acpartsdistributors.com/inde...ducts_id=38936
Old 07-28-16, 04:04 PM
C
Received 21 Votes on 18 Posts
If the other specs (horsepower, voltage, size, etc.) match up, there is no problem substituting a capacitor motor. You'll just have to find a place to mount the cap.
Old 07-28-16, 04:14 PM
sgull's Avatar
Not sure I'm clear on needing to find a place to mount the cap. The cap is already mounted on the (potential) replacement fan motor
Old 07-28-16, 05:41 PM
C
Ah...I thought it was just sitting next to it. Then assuming it isn't the way mechanically you are good to go.
Old 07-28-16, 06:21 PM
sgull's Avatar
I think you're right, in that picture I guess it is just sitting next to it. For some reason I'd assumed at first, looking at that picture, that it was mounted on the motor but I suppose not. So no problem just going ahead and changing out the old bad motor with that new one in the picture, but just don't bother doing anything with that cap?
Old 07-28-16, 07:23 PM
C
If it isn't attached to the motor, it comes with a mounting bracket. Just find a place close to the motor where the wires will reach and fasten the mounting bracket to anything convenient. It's just to keep it from moving around.
Old 07-28-16, 07:54 PM
Received 2,953 Votes on 2,664 Posts
Yup.... the cap is loose and you mount it where convenient.
Old 07-28-16, 07:56 PM
sgull's Avatar
When I go to the following cross reference page and enter in the model number of my seized motor (7163-9383) it provides a model D1126 as the new Fasco model number: Motor Cross Reference - Fasco Yet a search at Amazon for that model it shows the motor as being 1/15 HP, whereas my original (7163-9383, same model number as shown in first post this thread) is 1/20 HP. Here's the Amazon link: https://www.amazon.com/FASCO-D1126-M...ds=fasco+d1126
Wonder what's up with that? Any further comments appreciated.
Old 07-28-16, 08:05 PM
There are usually several subs for motors.
Many times they use different caps to change the horsepower rating.
Old 07-28-16, 08:25 PM
sgull's Avatar
The D1126 then should most likely be a proper/acceptable replacement sub then? No cap with that one (just like no cap on my seized one either).
