Replacement electrical panel door
Old 07-28-16, 04:50 PM
C
What are my options to replace this door? It's old and the hinges are failing and latch is broken. I am not putting in a new panel just because some hinges are broken. I know I can do something to fix it, but I would much rather replace if possible. Is there a current replacement? Source for hard to find/vintage parts? I think it's from the 70's.
Old 07-28-16, 05:35 PM
C
Received 28 Votes on 23 Posts
Sometimes spare parts are available for load centers, but I think you will have a very hard time tracking one down; they are not widely available, and are mostly for industrial and commercial panels; not residential.
Epoxying on a rare earth magnet or two would be a quick way to keep it in place and closed.
Old 07-28-16, 05:41 PM
C
Thanks Carbide. That was my thought too, for the latch if I can't find a replacement. Any idea where I can determine part numbers for this panel? I see an accessory lock part number is printed on the door and that part is on eBay. Makes me think if I knew the part numbers of that latch, door or even the whole panel, I might be able to locate one easier.
Old 07-28-16, 05:46 PM
C
Should be right on the label in the section marked "Cat NO"...can't read it in the pic.
Old 07-28-16, 06:19 PM
C
Got it. TLM612S or TLM612F
Searches mostly result in the modern TLM612SCUD model.
These are the spring steel hinges and the latch handle I am after. Mostly the hinges.
Old 07-28-16, 07:38 PM
C
This place says they have the panel (whole thing); guess you could see how much and decide if it's worth it just for the cover.
Your box is flush mounted, which means it should be the F.
Habet & Habet Ltd. - Belize Building Supplies, Belize Building Materials, Construction Supplies, Belize Hardware - GE Panel Box 4/8 125 AMP
The page is for a different box, but the note says they also have yours. Must be new-old stock if they do.
You'd have to make sure they don't send you the new version....
Old 07-28-16, 09:02 PM
Received 30 Votes on 21 Posts
Have you tried calling GE to see what they say? Might get lucky and find that the new cover is still a valid replacement for the old one.
