3 phase to 1 phase calculation
Old 07-28-16, 08:45 PM
E
Good day, I do have a question about generators. Let us say I have 100 KVA, 3 phase, 440 Volts with power factor of 0.8 and the I want to convert it into single phase with 220 Volts. What would be the KVA equivalent in single phase?
Can someone provide with calculations or other suggestions?
Thank you so much.
Old 07-29-16, 05:37 AM
B
Received 81 Votes on 72 Posts
The answer is in your textbook. Read it!
Tolyn Ironhand's Avatar
Received 205 Votes on 182 Posts
In the US standard voltages are 120, 208,240,277,347,480,600. You mentioned your voltages are 440 and 220. You will need to verify the voltages in your area.
