Ideal voltage for equipment
Old 07-30-16, 04:50 PM
9
Hello everyone,
I have equipment that states it can take voltage from 200-240. If you could choose your voltage what would it be. I am putting on a UPS to the system and I can select different outlet voltages.
Thank you
Old 07-30-16, 05:28 PM
Received 2,977 Votes on 2,686 Posts
The higher the voltage.... the lower the current draw reducing the need for larger wire.
So I'd set it at 240v.
Old 07-30-16, 07:26 PM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
It will really depend what you have available. If this is in a home, then your voltage available is likely 240. If this is in a commercial setting the voltage available will either be 208 or 240. Your equipment will run fine on either. Spending money on a buck/boost transformer would be a waste of money.
Old 07-30-16, 07:53 PM
A
Received 81 Votes on 73 Posts
For most UPS units you want to select the same output voltage as your normal input. You really don't want the voltage changing much when the UPS kicks on and off. Otherwise lights dim/brighten and motors can change speed.
